Courtesy Reminder: Price Adjustment for eisy Coming Soon!
We wanted to give you a heads-up that due to increased tariffs, the price of eisy will be going up starting May 3rd, 2025, as follows:
eisy | home $352
eisy | OpenADR $572
If you’ve been thinking about migrating to eisy, now’s a great time to do so before the new pricing takes effect!
We’ve made it easier than ever to migrate from your 994 and Polisy!
- For INSTEON devices, migration is as simple as a backup and restore.
- If you’re using a 500 series Z-Wave unit (models with ZW+), migration is also easy but may require some manual intervention.
- Your ISY Portal licenses and Alexa/Google Home configurations transfer with a single click.
- Extend your system with 100s of plugins: [Click here for the list]
What You’ll Need:
- 1 x eisy
- 1 x Serial PLM Kit (only if you want to use your existing 994 PLM)
- 1 x ZMatter USB if you want to use Z-Wave/Zigbee/Matter (currently out of stock)
We’ve prepared exhaustive migration instructions to guide you every step of the way: [Click here for the full guide].
April 23, 2025 @ 7:44 am
Please don’t use the Tariff to raise the price. If you going to raise the price, raise the price. We all know that you found an opportunity to do so.
April 23, 2025 @ 7:49 am
What an insulting and meritless comment even though you probably already know that we are hit with 20% tariff and almost zero inventory. With the same thoughtless logic, when we reduce the price after tariffs are gone (hopefully), then we should not notify anyone and just reduce the price.
April 23, 2025 @ 8:17 am
I’ll keep it nice, professional. The first comment probably has no insight what it takes to run a business and how all the pieces must fit to stay in business, succesfully. Even with the increased price point I care more or less what it is. Universal Devices is doing things for me, every day, cheaply. It is sort of like Netgate, just their documentation makes it worth buying a a 2100 and leave it in the box. It is about learning, keep learning and exploting. I am just very appeciative of their existance. These products actually make my life better. Kinda hard to set a price on that. Don’t reduce the price later, keep working on that Windows interface vs Java.
April 23, 2025 @ 8:19 am
Thank you very much!
