SPAN: Take Control of Your Energy Usage!
SPAN plugin allows you to monitor the power consumption of individual breaker circuits right from your panel.  Easily connect or disconnect specific breaker groups as needed, while gaining access to detailed hourly and daily energy consumption data. Whether you’re optimizing usage or troubleshooting, this plugin provides the insights you need for smarter energy management.
All communications are local. A node is generated for each panel and each breaker group is represented as a sub-node.  Each breaker group can be opened or closed and immediately accessible in Programs.
If a backup battery is present the remaining battery percentage is also shown.
Prerequisites:
  • eisy – enjoy a $40 discount when you upgrade to eisy using coupon code SPANIO25 (expires 01/15/2025).
